All parts will work on either engine. Some of the 5.5hp motors have a shorter crank, and that makes them 190cc. But it can be replaced with the bigger 6.5hp crank/rod/and piston to make it 206cc.
The Animal is the same exact as the 6.5hp motor. It just has a better carb, aluminum flywheel, and a slightly stronger block.
