Briggs Intek/animal build
Currently building an Intek to animal spec, already have a Briggs animal rod on the way soon to get the stock animal flywheel. Does stock intek coil have a limiter built in ? Will I even be able to use it for the animal flywheel? Helps appreciated, thanks
The stock Intek coil does not have a built in rev limiter. If you get a PVL animal flywheel you will have to have the matching coil. There are rev limiting coils available for the PVL flywheel. Black PVL coil limits at 4100rpm, the Green PVL coil limits at 6100rpm, the Red PVL coil limits at 7100rpm, the blue PVL coil has no rev limiter.
Actually I think the blue PVL might be 11,000 rpm limiter?
