I was thinking of all the people that come in here and ask questions about what they should do to their motors to get more hp. And to the newbee some of the answers might be confusing. So lets build a Hemi....
Step by step..... from the very start... as we go through each step I want to come to a concensus as to which part to use and why. As well as links as to where to get each part.. like I said. We will start with a Hemi....strip it down to the block.. and start with the block itself. Everything from removing the low oil sensor or not and why. Blocking the hole and how? Removing the governor or not and why? How? Blocking the hole? Put in a vent tube there? Why? Where to get the stuff to block the holes? Etc.... then maybe move onto other engines? Once a step is done then its done. On to the next step. And remember future steps may depend on what was done in the previous steps....
Remember this is for DUMMIES
Step 1)
How far should we strip the block down? Should we strip it down to nothing or just as far as we need to for completion of the step? Remember Step 1) Preparation of the Block.
I am assuming some people may lose parts that they may or may not need later.So keep that in mind.
I would remove the tank. Remove the oil sensor fill the hole and governor and fill the hole.
Where would anyone start or do? Remember this is for Dummies but we are building an engine with bolt on parts that can be bought. Modified parts will be fine as long as they can be bought and installed without any modifications such as welding,grinding or cutting.
Step 1)
