Car leaks after jet install!!!!!
I was running .028 size jet and noticed i had bad throttle reaponse. So I ins5alled a .032 jet....runs perfect but now carb leaks. It seems like its coming from the top of the bowl. I made sure I put rubber seal back in... I need help.
Upgrades: dyno cam. 18lbs springs. Header. Air filter(no flywheel but soon to come)
buckeye
Did it leak before the new jet? Nope.
So, you put something together wrong.
Did you,use a new,bowl gasket?
Did you change anything with the needle seat valve?
Have,l you cleaned anything?
If it wasn't leaking prior to you rejecting then something happened when you rejetted.
CarPlayLB
If I recall, the bowl has a rubber o-ring. If it got pinched or rolled it may leak. You will need to check it again. Also, are you sure the e-tube and jet are seated all the way? If they are not, the nut at the bottom of the bowl won't allow it to tighten properly
