Chain clutch recommendation?
250ATC
New Member
I’ve got an old Baja Beetle retro fitted with a fully built predator ghost 212. It’s a 35 chain, 3/4 bore and I tried using a master of motion 12 tooth clutch. It exploded 5min in, the sprigs between the clutch pads are bent and over extended. I can find a clutch that’s over 7hp rating. Any suggestions?
I've been running a regular 12t Max Torque clutch on my DB and it's held up fine on a stage 2 Predator 212 that's definitely putting out more power than your Ghost. I am running a 70t rear sprocket on it though. I'm also 225lbs, so it's got some weight to move.
