Chrome Cleaning trick
If you have surface rust, here is a tip to clean it.
Spray rusted area with Windex. Brush with Brass (brass won't scratch) brush.
Wipe away rust with a rag.
Before
After
I have used the brass brush with chrome cleaner before but not with Windex, Did you watch My Big Fat Greek wedding one too many times.
That looks like it worked great. i used balled up aluminum foil and water. Dip the foil ball the in water and scrub away. Ir got the rust off in a split second.
I have done that before, this is so much easier. I have even used Coke insteadt of the water, but it left if a little sticky.
another one is take old blue jeans cut in to strips and king Midas metal polish . it leaves a coating on the metal helps stop rust , for a while
