Well to be honest, I'm a rook, this is the first time I have done any upgrades on an engine. So I have a Champion brand clone. Therefore, without exchanging the head I will not use 1.2 rockers since the champions come with shaft mounted rockers. I have the governor removed, a billet flywheel, I will be getting a billet rod with bearings, an RLV port matched header, an AGK intake with a PZ22 on the end, obviously some jet adjustments, and 18lb. valve springs.
I am just toying with the cam upgrade right now which is why I am asking how it will affect everything else. Sometimes as you know, you upgrade one thing and you have to follow with upgrades on other parts of the motor.
Since I am somewhat new to this, what is coil bind? Is that a binding up of the springs? What do I have to do to avoid this?
Also, I have heard about cleaning up the short side radius but to be honest I do not really know what this means. I understand that this is a matter of port work, but I do not know what someone means when they refer to the port side radius. The timing is not advanced, I had a Honda GX160 flywheel that I was going to work with which I understand would have provided a 4 degree advance, but I decided to go with an ARC flywheel instead due to the lighter weight and durability. I do not have plans to advance timing since I am not really trying to go crazy here, mostly supe it up a little and learn. If there is a benefit to timing advance that I should consider, please let me know. I appreciate any experienced advice on this.
