Clutch or torque converter
Bought first baja warrior 200.was told needs a clutch.ive read some people install torque converters instead cause the clutches on these things suck.id rather go cheaper route and get clutch unless it's just not worth it ya know.i think this bike is a mb209 but im.not sure.does it have 5.5hp or 6.5.heres the vin,I think.lol it is LOFGAL1G8DA023957.what kind of clutch do I get? What kind of TC is best?
When looking for a clutch online I've seen some bikes were 5.5 or 6.5hp.i was thinking 6.5hp on this one but when I seen clutches they would have 10 tooth or something about #40 or #41.im not mechanically inclined.my cousins going to do the work I just need to know im.ordering the correct parts
Hello and welcome! Nice Baja! Typical 196cc clone (Chinese copy of Honda engine), 6.5 HP. Make sure the PTO (end of crankshaft) is 3/4" (it should be) and order a Chinese CVT (AKA: torque converter) with a #40/41 sprocket ($50-55 on eBay and elsewhere). They come with metric bolts (4 mounting bolts and one crank-end bolt); it seems that most clones have SAE threaded holes, so you will probably need SAE bolts (don't mess up the threads by using the wrong bolts like some people do; if the metric bolts don't run in easily, you need SAE bolts; don't use a bolt that you can't run in with your fingers). OldMiniBikes Warehouse sells an SAE bolt kit to simplify things. @noseoil has built a few of these bikes and could advise you on what works or doesn't. Baja is defunct but the website is still up, you may find some useful information there.
https://www.OldMiniBikes.com/predator-212cc-mounting-bolt-kit-for-tav2-torque-converter.html
https://www.walmart.com/ip/COMET-TO...s8o8KccDA3HTvDpQxtl3U2a3tJ8Zswd0aAnH2EALw_wcB
http://www.bajamotorsports.com/categories/minibikes
http://www.bajamotorsports.com/parts_catalogs
https://www.oldminibikes.com/forum/index.php?threads/new-baja.143372/
https://www.oldminibikes.com/forum/index.php?threads/new-bike-another-warrior.150548/#post-1148576
Thank you so much.what is the bolt kit called at OldMiniBikes that I order
First link posted above. You can get the bolts at any hardware store (for much less, I imagine) but I don't remember the sizes and thread pitch. You may not need them; I know the 212 Predators do, but I don't know about the Baja's 196. The OldMiniBikes kit is $10 + shipping (free shipping only on orders over $150), or you can buy it through Amazon for $12 with shipping included.
https://www.amazon.com/OldMiniBikes-Warehouse-Predator-Mounting-Converter/dp/B078ZPYNP3
I74
280cc, I would think it would have at least 6.5+ hp & then some ....
I got to get my eyes checked.o_O ''OOPS'' .:oops:
It looked liked it said 280cc in the pic., also,, the different cover thru me off. LOL !!
CVT is the way to go. I grew up on centrifugal clutch mini bikes in the 70s and now have scooters with CVTs. The CVT will allow you to go up steeper hills and maybe a bit faster. I haven't experienced one on a Baja yet. I just got mine the other day and it's the first mod I plan on. There are youtube videos on the installation and results.
