The center part of the clutch should spin fast when you give it a little gas. It has shoes in it that have to spin around 2000-2200 before they lock to the outer part to drive the rear wheel. Give it more throttle and see if it locks and quiets down. It's a Max Torque, so it will still make a little noise. If the noise you hear taking off is kind of a hissing rattle, it's normal. Metal shoes spinning in a metal drum will make noise until they lock up and start moving you.
