Here is what I found out by researching the Coleman CT200U mini bikes that were sold by Cabela's and BJ'S.
The Coleman CT200U is built by Hisun Motor Corp USA meaning all final assembly of Hisun products are completed right here in Carrol Texas. USA. They are now selling the same Coleman CT200U mini bike under their own name "Hisun" and they look identical to the Coleman bike with the same heavy duty rack system. Hisun Motor Corp also sells UTV's and ATV's. The Coleman CT200U is a well built mini bike that has a larger frame and bigger wheels than the Doodle bugs and also come stock with a Hisun 196cc 6.5 HP engine that very closely resembles the HF Predator 212cc engines. It also has a factory Jack Shaft system on it which gives it a good final gear ratio right from the factory.I am just finishing up on my build and bought a do it yourself header kit from OldMiniBikes so that I could route the exhaust between the frame and rack upright. I also installed the same K&N style air intake and adapter as the Predator 212cc and it bolted up and fit right, I re jetted the carb with a #38 jet and the 140 emulsion tube set up for the predator 212cc and it worked out great. So far all the Predator 212cc performance parts fit on the Coleman/Hisun Mini Bike. The Coleman CT200U ran like crap with the stock parts but now with the OldMiniBikes Warehouse performance parts it is running like a little devil. My next upgrade is the Chinese TAV2 CVT clutch install which I will be installing today. My last bike (The Doodle Bug) was a rat rod build, this new Coleman build is a rescue scout bike. I'm having way to much fun!
My recommendations:
1. Install an exhaust header. ($19.99) Gotta have a welder though if you use a do it yourself kit!
2. Re jet to #38 jet and install the 140 emulsion tube. ($15.00)
3. Install the K&N style filter and the Carb Adapter. ($29.00)
4. Back out the Governor set screw for more throttle response (FREE)
5. Ride it like you stole it!...
Just these few easy upgrades will wake that stock box up and you will see and feel the difference! it sure put a smile on my face!
My recommendations:
