Ok so I recently got the 212 and put it on my mini bike. Now when I got it where the throttle hook up is suppose to go which is on the governor throttle I put it but it was super stiff. So I eliminated the governor throttle and ran my throttle cable to the little swing arm thing under the gas tank. It's between the gas tank and pull start. But anyways now when I accelerate it pulls the swing arm thing which has a metal arm connected to the carb so it's a very direct thing and it works good. But my question is since my throttle is basically directly almost to the carb and I don't have the governor throttle hooked up does my governor still work? I haven't taken the gear or the weights out or anything. But I'm assuming it's just in there doing nothing like if it basically has no governor which is good. That's what I want. But idk. You guys let me know if you think it's still working or not. I'm hitting 37mph max bone stock btw. Thanks.
