Damn covid has got me in a $pickle$. I have been screwed by short hours, but work just enough to not qualify for any of these covid payouts. Have watched my savings go to nothing in just a few months. make me offers!! Shipping is on buyer, PayPal F&f. Only allowed 3 pics so let me know what u need showed more of
Full unbuilt big bore stroker GX200 partout + other down bottom
$400- genuine Honda block, 2.915 bore, extended .080, welded pin, Wiseco piston, custom cut cometics head gaskets included
$250- ARC 2.3" stroker crank
$75- ARC 3.625 stroker rod
$125- Dyno cam, adjustable billet, custom cut, exact specs I'm forgetting, but something like .300,245d,
Ex/.285,260d, In. Cut for power and ratio rockers!
$125- ARC dual bearing sidecover
$30- Clements top plate
$125- ARC PVL lite flywheel, has different numbers. But was cut specifically to this stroker crank taper. I'm keeping pvl coil for another project.
$120- Gage Warhead, blank
$175- Gage rollers, black venom 1.35 ratio
$150- Raceseng valve cover, I countersunk inside bolts. New with original box, gasket
$50- Raceseng valve cover spacer, 1/2" black
$250- EC 304 dominator, alky, extra red goodies included
$300- 3D manual clutch, full kit,
$ Odds and ends, New bearings, gaskets, studs sets, raceseng pushrod guide and timing tape. A bolt on ovh brace setup that bolts to a top plate
Valves, 28/32 5.5mm stainless,
28/32 5mm stainless,
30x5m, 33x5.5, 29x5.5 Titanium(need cut to length depending on build
Bronze guides, bronze seats,
Everything past here goes to something else, new and used. make offers!
$300- blockzilla 2, 3.012, could use a new sleeve(I have one) if u plan to race it, or run it on a yard kart/mini bike, comes with blossom head,
Have spare blockzilla sidecover and a new piston also, will sell if block goes, package deal?
$50- ARC 3hp drag flywheel, Briggs
$50- 3.5" piston, used for mockup, no rings
$50- mini drag bike piston 2.992
$50- domed Briggs piston 2.992
$60- Briggs standard Wiseco + long rod
$40- Briggs 3.875 rod new
$75- 26mm mikuni round(genuine)
$75- 24mm mikuni flat(genuine, alky)
$150- ARC breather for blockzilla, single out
$100-ARC adjustable timing setup
$200- horstman X5 clutch, basically new, + extras
$400- twin burco mikunis bm34, kawi manifold
$200- military spec hr196 with billet stack
$300- twin Posa fuel injector carbs 26mm
Also have some random Tilly's kicking around, other stuff maybe, just ask, make me offers.
