Sticking Valve...a Theory
The exhaust valve on the '74 was really caked with carbon build up. When this engine was torn down, I noted the side cover was not very tight and there was oil caked everywhere. It seems the cover on this engine had been off before.
When reassembling, I noticed the exhaust valve spring was canted on the valve. Thinking I hadn't got it on properly, I removed the spring and retainer and tried again. Looked good...I rotated the engine through one revolution and the exhaust valve stayed open, and the spring was canted over again.
So, what I surmise is the correct bolts for the top two side cover location went missing sometime along the way. All of the bolts were the same length--and one bolt bottomed out on forward side of the engine, and the other went too far into the valve spring chamber. The solution was to cut the bolts down 3/8".So smooth valve travel and tight side cover.
