And boy was it easy...
Grabbed a Baja Dirt Bug this past weekend for a decent price. Needed nothing but a rear tire...bald and slow leak.
Had already ordered a Predator for my Motovox MBX11, which is like brand new. Decided to put it on the Baja instead.
Had the old engine off in 5 minutes, and slid the Predator on to see what issues I'd have.
Only issue was the crossbar that fender bolts to, was hitting the OHV cover, not allowing engine to sit flush on engine plate.
Used a pipe bender to slightly tweak the crossbar and then eyeballed the clutch teeth with the rear sprocket. Marked the holes, drilled them out, lucky 1st try was dead on...or dead on "enough", lol.
Hooked the throttle up, added some oil, and gas, and 2 pulls later, running like a champ....
Somehow forgot to grab a 5/16" fine thread bolt to hold the clutch on, so couldn't ride it but it sounds great. I will add a TAV from OldMiniBikes soon, but wanted to do it as simple as possible...
Only "issue" was the starter housing was bent in, keeping pull cord from working...evidently that was why the box looked so beat up...had to massage the cover a bit, and as luck would have it, didn't see it until everything was bolted on. ...
Next predator will be picked up at a store, and not shipped..
Can't wait to swap the Motovox now...
