Rather than zip tying the governor some of the easiest mods you can make to a 196 clone cost nothing. The second easiest costs less than $20 normally. On the governor arm itself there are several holes the governor linkage can be set to. Putting that the furthest out so the governor itself pulls back the throttle less will safely increase speed. There is also a throttle stop screw on the throttle plate that can be adjusted or removed entirely.
The dirt cheap mods are to replace the stock carb with an adjustable stock carb with a bigger emulsion tube and main jet, there are kits you can buy on amazon for ~$20. Just bolt on and there is basically zero adjustment needed typically outside of setting the idle screw. The slide carbs like the VM22 and Nibi carbs typically take a lot of tooling around to get running right. The final cheap thing that can be done is that most of these bikes come with a jackshaft setup that also limits speed, it's common to remove the jackshaft and straight chain it from the clutch to the rear sprocket with an idler added to stop the chain from rubbing the frame.
I've seen enough pictures of things going wrong with stock parts that I don't think it's worth the risk. I know it's also possible to get a bike to go 45mph on a governed engine and that is plenty of speed for a day to day rider, honestly 30mph is enough. One of the last things you want or need is the flywheel magnet coming loose and tearing off the ignition coil. Or the connecting rod giving out, destroying the crank and potentially leaving a hole in the engine block. Better to do safe mods for now, save up for a rod, flywheel and a mild cam before going down the route of removing the governor.
This is a 212 that I stuffed about $300 into. It costs more than the Predator alone did that I got on sale for $100, but it beats buying 4 predators over however long they would survive without governors.
