Front & Rear 15x6x6 6 ply Tires
Hydraulic Rear brake
PMR Jackshaft with cover
Noram Cheetah Racing Clutch
#35 RLV X-treme High Performance Gold/Gold Chain
Gearing 12t Clutch, 17t In, 13t Out & 65t Rear 7.1:1 ratio
RVL split rear sprocket
PMR engine plate
Gx160 Clone
Honda head ported
Chrome Moly pushrods stock length
26lbs valve springs
Retainers & keepers
Stainless steel valves 25mm & 24mm stock length
Hp lash caps
Stamped 1.2 rockers
Steel guide plate
MLS head gasket .036
Autolite 3910x spark plug
Stainless Honda lifters
Cam .275" lift and 238.5 duration @ .050" lift
Honda Gx200 Carb .670 max bore, 140 emulsion tube, pilot jet .020 & 98 main jet
Manifold with pulse fitting
Flat top Honda piston, wrist pin & clips
Billet ARC stock length rod
Honda Coil
MSD spark plug boot
Honda Stock crank
UNI air filter with billet adapter
Outerwears Pre Filter
4 degree aluminum flywheel
Grade 10.9 Bolt Kit With Washers & solid Dowel Pins
K&N type breather
Mini Tach
Under seat header
Heat Treated Exhaust Thermal Sleeve
RLV muffler
Cool Power Green Medium Oil
Running 110 Octane gas
$950.00 No Trades, Cash or PayPal no shipping
PMR engine plate
Gx160 Clone
Honda head ported
26lbs valve springs
Retainers & keepers
Hp lash caps
Stamped 1.2 rockers
Steel guide plate
Honda Coil
MSD spark plug boot
Honda Stock crank
K&N type breather
Mini Tach
Under seat header
RLV muffler
