Dual bearing/steel bore Briggs 5hp built up
125ccCrazy
Fresh build...dual bearing steel bore block, new bearings, ARC rod, 300 lift cam, cut spring pockets, new hd springs with locks and retainers, ARC flywheel, new valves, new piston/rings, screw in header adapter, new coil with 8mm wire, painted with two part urethane automotive white paint. $300 long block, $350 with mikuni and intake
pics to come
