Dupor 196cc OHV Racing Engine
dirt
New Member
i was looking for a blue clone to shelf. i found these for $99.00 Dupor 196cc OHV Racing Engine
Piston is .008" to .012" in the hole yielding a low 27cc combustion chamber volume - great compression
Ruxing Carb with adjustable idle mixture screw* .039" butterfly and .117" throttle shaft - best flow and fuel signal
High Flow Head Casting - We know which castings are good, and requested them!
Sidecover bolts with serrated head flanges - won't back out from vibration
Forged 2.130" Stoke Crankshaft (max stroke is 2.133") with hardened rod journal - strong, durable, powerful
Chemical Resistant Crank Seals - resist leaks longer
you must use a billet flywheel on thess.
