I have an old Cat with a 3hp Tecumseh.
I want to isolate the engine vibrations from getting to the frame.
The engine is just hard mounted to the steel plate with bolts like most minbikes.
I tried adding some vibration pucks used for air compressors under the engine. They work great at eliminating the vibrations but the engine moves around to easy and the movement loosens the chain and it pops off. I added one to stop the side the side movement from engine to frame and another one to stop the fore and aft movement.
The engine still twists and the chain falls off. If I ride it slow and easy, it is fine but any fast acceleration pops the chain off. Oh, this is a new chain by the way. I rode it with the new chain prior to this and it didn't pop off.
How do you guys eliminate engine vibrations?
I wasted a lot of time and money on this idea :-(
These are about 1" in diameter and 1 1/4" tall. They DO wok but you can't hammer on it. What fun is that?
Danford1
PS I tried to edit this post to correct my typo in the title, but the "system" won't let you edit the title...
Danford1
