New plate, new kick stand..... We will soon ready to start the painting sequence after a general cleaning piece by piece..
The front disc brake is a joke, commercial subject only....
Hello, Clutch and 4 speeds...
"Vermont will register a motor-driven cycle (moped) is defined as: 50cc engine or less, 30 mph on level road, automatic shift, seat/saddle for rider "
Yes but at first I have trouble with the pin from the kick starter. I drilled it but I want to save the shaft and the kick...
First cleaning from the frame, I found the original color . Swingarm don't want to be removed
, I need push out the axel ...
I drilled the pin and pushed it with a hammer & screwdriver. It took me a week to be able to remove the pin.
The cover is really damage and one screw is broken from the clutch basket...
I will try to find a new cover....
Good news: After cleaning I will be able to repair the cover.
I drilled to stop the crack, I removed all the epoxy not properly done .
It will next step to repair it and reinstall the inspection cover.
