Just finished up the ten Briggs & Stratton motors for the ten Fox Campus bikes that I am restoring and thought you might like to take a look at them. I decided to go with five of the 3hp and five of the 4hp. All of them have been blueprinted to factory specs. with all new internal and external components being replaced as needed. The only compromise that I made to originality was replacing the old points and condenser type ignition with modular electronic ignition systems. Each one was completely disassembled, degreased, bead blasted, primed and painted in the original Briggs "ice white" color. And the best news is that I didn't have any parts leftover. Always a good sign. Actually; I've got boxes full of parts that were not re-used. All that's left to do now is build a test stand and give them their initial test run. Getting too cold outside now so will do that in the spring. The Campus project is coming along fine and with any luck I should have them all completed by the end of 2016. Thanks for looking. Ogy
