Installed NOS rear brake caliper and it drags on sprocket. Anyone have tips and tricks to setting up rear caliper/sprocket on Fox models? Do I have correct spacers? Thank you
If your wheel or sprocket is bent it will drag ,you may have to sand down the pads for clearance if they are not to tight ,if cable is to tight they also will drag.
