I've spent weeks and weeks looking into this and have discovered sadly nothing currently is produced? mb165, mb200, motovox, Honda wild money Z50 or something like that
There's obviously a million ways to go, but I want to find the easiest and cheapest. The stock head stem likely has to go which isn't such a bad thing. After tons of pages, sizes, heights hts I've found Harley wide glide triple trees top outer leafs are 1" so they'll fit pw80 forks. 10.5" wide center to center with PW forks being 26mm wide exposed, they're probably around 42mm at the base (total guess). Leaving approximately 8.85 inches from bolt hole to bolt hole. I know pw80 is only 10mm bolt hole but 12mm OD x 10mm ID Bushing Adapters should easily do the job or just get bigger bearings.
Do you think it's a good option to go the Harley route?
