Head light to batt. LED conversion
I'v been asked to show this. So here what i'm doing.
LED lights are very rugged. And LED headlight can be very high in price. Also getting light on a mini bike can be a hassle.
So.......I am taking a $5 LED flash light and a Baja head light and making a battery operated head light.
When the JB weld dries. I will be cutting off the battery area of the flashlight and removing the switch.
Bullhead
delray
also you can go on to ebay and find leds that are built on to a automotive bulb. for example a 1156 and fab a bulb socket on the back of you headlight housing.
here is one i did for my project build, but at the end of my project i desided to change my headlight. still is using a led setup. just little different led then what i had posted originally.
factory setup
new headlight socket that i fab to the housing
out of the package
using the new flat style leds and seam to be ok?
more the leds point into the housing, the brighter it will be.....:thumbsup:
http://www.oldminibikes.com/forum/project-logs/12275-project-build-rear-springs.html
