Yes, and bounce the needle up and down a few times, because Tec carbs are notorious for having finicky needle valves, especially after sitting.
About your pull starter- That tiny torsion spring that fell out is supposed to provide tension to the little metal pawl that fits in that plastic slot. The center screw is supposed to have a tiny coil spring that retains the tension on it. Sorry Eric, no locktite on that.
A lot of people here would be glad to help you. I'll volunteer to rebuild, derust and prime it including replacing any missing parts, for the price of shipping and any parts. (cheap) But you might find someone nearby willing to lend a hand. When I rewind those, I have a couple of plastic clamps handy that allows me to tie the figure 8 knot within the pullstart handle.
The center screw does have a coil spring on it but it may just be worn out, not sure, but it does not want to stay in place. If it's anywhere near tight, the rope will not retract. Does that have something to do with the torsion spring not being on there?
