I have a HF engine that is going to be installed in a old Speeco 3 wheeler. I will be using it on our property and hauling deer on homemade small trailer. Biggest thing is to be reliable and a bit more low end power. The current mods as follows:
Governor delete. (left stock springs to limit RPMs due to running Baja heat flywheel and stator)
High flow air filter and valve cover breather
Idle rejet (74 bit) and main jet (65 bit) jury still out.
Pulse pump
Future mods
Billet rod
header with OEM muffler or tractor stack muffler (I am limited to 91 decibels on public lands)
GX160 head with mild porting
Give your thoughts or advise,
Thanks, Dan
Pulse pump
Future mods
Billet rod
Thanks, Dan
