Yeah.. stuff will do that.. Uhhhh see if your tire is not on the wheel right...
OFTEN the tire is not true to the wheel when it's inflated, so even though the WHEEL itself is rolling true, the TIRE will be out of round because it's 3 inches tall on one side, but 2 3/4 inches tall on the other side.. :doah: If it's out of whack you can deflate the the tire to about flat, then fight and pull and wiggle it until it's rolling smooth, then re-inflate..
If the wheel bolts to a center hub, make sure the wheel is bolted on perfectly centered..
