I used a HOK silver metallic base clear coated with HOK urethane for the frame. Not a lot of difference in silvers out there I've noticed. Someone mentioned that Cortez silver to me for the cases. I don't mind, and have all of the paint equipment, but keeping things uniform is something I strive for. I note that on the Hodaka web site, there are many varying opinions on the silver case paint question. I'm finishing up an ACE 90 for a 1964 and picking up jug shortly from boring. Meanwhile, I have an E code for the MX Bonanza that I will swap out, and then use the Hot Rod Fuji on a nice Steen I will be finishing. That is the plan anyway! Thanks for the scoop on the paint!
Side note: I was unable to get the Fuji kick starter to quit striking the frame. I moved it over, and then had JS alignment issues, etc. So I didn't do that frame any favors, even though I used a "more bent" P code Hodaka kick starter. I have since heard that for the MX frames this is always an issue and can be mitigated with a model 94 Wombat kick start lever, as it's bent out even further. Live and learn!
