I have the POWER!
I purchased a flywheel and 2 lighting coils on ebay that are listed as fitting a GX160/200. I paid like $42 I think. The flywheel came with a starter ring attached. I had to remove it in order to clear the ign. coil. I then tapped the existing holes with a 6mmx1.00 tap and installed 6mmx30mm bolts.
These are listed as 3 amp coils. It looks to be juuuust enough to light two lamps.
I have it wired up to two lamps. Everything runs as it should. I put about 4 miles on it today.
I know there were some of you who were wondering like I was if these parts would fit. This should help you if you decide to do it.
