I ended up buying the HS50 I posted about in another thread. Model # 67207D, Serial # 3187B (Looks to be 1973 engine) Problem is it has a 1" dia shaft that is 3" long. Is it possible to to change the crank & sump cover to 3/4" dia 2-1/4" long like most minibike engines use? Also if it is possible to change crank will I be able to use same cam, flywheel, etc that is on engine now?
If not possible or too much has to be changed can a 3" shaft be used on a minibike? I did see 1" centrifugal clutches available and a member here said it was possible to use 1" shaft but the 3" length has me concerned with clutch cover fitting etc?
Any suggestions greatly appreciated.
Thanks
Thanks
