i need help with brakes on rupp c250
ok so i need to get brakes on my rupp c250 i dont have any mounting bolts on the back but i do on the front. i want discs but i dont know. i dont have the stock turbine rims. can sombody give me a list of parts. thanks:thumbsup:
heres more detail. i wanna try to mount the brakes and i have a 2 peice front rim with 6 bolts the rim is 7in ps. my camera broke
capguncowboy
and i belive i will be able to mount a rupp turbine disk on there but whats the specs on em. thanks guys you are so helpful
Can you mount the brake on the rear and use the sprocket as the disk?
The other option is to use a band brake set up on your clutch. There are a few threads in the tech section advising how to do it depending on what engine you are using (tec, briggs, clone, etc).
