I screwed up
Ok so I posted about this 2 weeks ago. I took out the govener on my 5.5 Honda clone. I just took out the plastic gear. Then when I'm riding the govener rod was hitting against the gears. So I took a dremble and grinded it off. Now it wont start. When I try to start it it sounds like the damn wheel of fourtune. The gears are in the right place with the markings. It sounds like metal it's hitting toghether when I try to start it. Any ideas?
Well I removed the plastic gear with the weights in it then took it for a ride and it was fine except the rod was hitting the gears. That's when I grinded it off and now it won't start. I've looked all over the inside and I cant see anything wrong
1. Won't start 2. Sounds like wheel of fortune 3. Removed govenor :scared: - No offense but 3 strikes against you. It may be easier to go buy another discounted clone. Be sure to check for a sheared off keyway.
