I am stuck between it’s original and I want more power. I have a 3hp and a 5hp Briggs. The 3hp arc billet flywheel will fit the 3hp and also the 5hp with a coil drop bracket? Arc flywheels are much safer for mini bike applications? I wanna build up the 3hp with a mikuni and flywheel etc. While knowing I can swap the flywheel to the 5hp with the drop bracket and build up the 5hp later. Would you build the 3hp or would you build the 5hp with a 3hp flywheel or just keep the h30 stock?
