Have a look at the hand throttle on the engine (the lever you would normally move to speed up or slow down the engine). Behind that lever should be a screw that the lever stops against. That is the governor adjust screw. Backing that screw out will increase governed maximum RPM. Should get you up to about 4000RPM.
