I believe the frames are the same. There are special mounts for the Hodaka engine that bolt up to the motor plate. OldMiniBikes warehouse has the motor mounts.
Sorry for the confusion. That badge is simply resting on a motor. The motor has nothing to do with this question. Based on the serial number, can someone tell if that badge is correct for a Hodaka engine? Thanks.
It would show wear from the Hodaka mount as well. Bolts down to the engine plate also. Looks like the frame is at least an MX frame if it is 7/8 inch tubing.
Yes that was a 1510, the long rust lines on the engine plate would indicate the hodaka brackets, as well as the sprocket sizes and muffler strap on the right side. shock mount.
