late tecumseh shroud/recoil assy-small frame engines
Dont know if anyone needs it or not.....
Late version from around a '95 shroud/pull start/backing plate and fixed postion throttle. The recoil is they type thats pre drilled and setup for the optional bolt on external lighting generator (if your lucky enough to find one.) Shroud is clean and straight and not stamped. Has the fixed position throttle assy, looks like one of these could be modded pretty easy if you took off the detents and a little tweaking. will fit the small engines H/HS like the powersports only without the ugly on/off switch in the middle of it.
Is what it is $24 shipped all you see in the pics:
