honda built top gear a 125 mph lawnmower. :thumbsup: nuff said!
How can I make it easier to understand?
The basic engine design does not adapt itself well.
Costs involved in machining and making parts exceeds the value of the engine as compared to buyin gor building a proper horizantal shaft engine.
I am going to date myself now.
But this is a great miibike engine.
Pou
Its design easily adapts to minibikes or karts its very small and light.
It can spun to high RPM without fear of exploding.
It makes good low end torque for is size.
Pound for pound and dollar wise ( if you got each for free ) the D44 makes a simpler, cheaper and easy to build engine.
But its just one example.
Just about any horizontal 4 stroke is better than a any mower engine and the first reason is they bolt in place.
Here is another good one the Chrysler 580 power Bee
It was so much better it could be adapted to cut grass, pump water or even run a trolling motor.
And the reason is it weas a well thought out in advance general purpose engine.
It was not designed to be a lawnmower first and only.
Here's a snowboy engine based on what I suspect is a c-17a.
Great lawnmower, shitty snow thrower, but at least OMC had thegood sence not to screw everything up by trying to tip it on its side ( they knew at that much would not work )
Here's a decent little Clinton you see on a mini every now and then.
Sometimes you found them on a mower.
But there was a good reason this ( and the techumseh uniblock and AH engines too ).
Because the design was ver strong and general purpose, strong enough in the case of the little Clinton to make a decent saw motor.
I am telling you this from experience.
Listen or learn the hard way.
