I did a search and couldn't find anything much. What I am after is more refined throttle control. I know these motors are made to run at a single speed so we have an uphill battle. I am running a 389 Champion. I hooked the throttle cable to the factory mount. The throttle gets harder to turn the further you turn it. And I can feel the governor fighting the cable. A delay in response. What I have done is order new driver springs for the TC to lower the engagement RPMS as I feel I don't need the higher RPMS with a bigger motor. Also will play with spring on the driven to fine tune it. Thinking the severe on and off response might be less. I know it will never have the same control as a trials bike, but looking to improve what I have. Of course first thought was to bypass the governor and straight to carb. Thinking I am smart enough not to over rev. Well I have two bad knees, an arm with scars, a short finger, and a divorce to prove I am not smart enough. So I am asking for advice here. Will rejetting the carb help? Any tricks to modding the governor or carb to lessen spring tension without giving up the rev limiter function?
