Hello,
I have searched here and found some threads but many of the links are dead.
Basically when it comes to 12v DC, I am very experienced using it and wiring things up. I understand it pretty well and don’t usually have many problems.
This is the first lighting coil I have ever installed. So working with AC power is something I am not very familiar with.
My questions are-
1. I am thinking about getting a bridge rectifier to change the AC over to DC. Are there any dangers/precautions/ suggestions for doing this? What are the benefits, if any and the negatives, if any?
2. I have a 12v headlight bulb and a 6v headlight bulb. I am pretty sure my tail/brake light is 12v. Do I need to run the same 12v bulb on the headlight too?
3. What size fuse should I use for these lights? I am assuming putting a fuse in the circuit is a good idea. Does AC or DC matter as far as fuses go?
My plan is to install (2) toggle switches on the top of the headlight housing. 1 switch will be to turn the head/tail lights on, the other toggle will be for high beam.
So 1 of the power leads will power both the headlight and the taillight. Is this a bad way to do it? The other power lead is for the brake light.
Again AC power is foreign to me, so even though something seems like a good idea, I really have no idea if it really is a good idea or not. Lmao
I obviously do not want to damage anything of fry bulbs or wires.
Thanks and have a nice day
My questions are-
