get a 130 main jet that will get you close. Pilot stock Is usually a 15 and it may work just fine. I have used 12.5, 15, and 17 pilots. Try the stock one and if you can get a good idle with the idle air bleed adjustment between 1/2 to 2-1/2 turns out your fine if you have to go an less than 1/2 turn then go to a smaller pilot 12.5 or if you have to go more than 2.5 turns out you need to go richer to a 17 pilot. hope this makes sense.
