the engine without the NOS
single bearing 5HP block (aluminum cylinder)
.010 bore briggs piston
ARC connecting rod (standard lenght)
factory crankshaft
dyno cam
comp cams lifters
comp cams double valve springs
factory valves
horstman fire slot head
copper head gasket
Billet 28mm Intake manifold
28 mm mikuni carb
3 hp flywheel
3 hp ig coil
adjustable coil bracket..........
