Got some time working on the BearKat 2022 . Normally the engine mounting plates are kinda narrow . I am using a Briggs and Stratton 8hp big block . But made mount wider in case . Something else comes along that’s different and has bigger bolt pattern . I made the 1/2 round stock long enough to be able to use a hairpin or cotter pin and washer to hold polymer/rubber bushing in place but there pretty tight . I slid the bushings on to a short piece of 1/2” chucked in my battery powered drill motor . I used a box cutter to trim the bushings to length . Much nicer cut than my band saw would do .
