what clutch should i use if i want more top speed, i dont want to pop wheelies, lets just say im not a daredevil, should 13 tooth be good? Or would that not be enough? Thanks.
And what about the thread pitch for the clutch? The old bolt doesnt fit, i got the hemi edition for the same price, so i just got it anyway, the carb is silver??? And it says gas pump on the side and i dont know why, is it an older engine or what?
If you have a thread pitch gauge you can find the thread pitch on the crank. They are relatively cheap to buy, I have 1 standard and one metric and they come in handy all the time.
ive run into a problem, the clutch didnt come with set screws, and the keyway was empty, but can i use the old 212cc predator shaft key that came with it? Will it destroy the shaft or will it be ok, thanks
