Hey guys im brand new here and this is my first post. I found a motovox minibike on the side of the road out for the trash (one advantage of having a friend who's a trash collections man). It had a blown engine on it so i bought a new predator 212cc engine from harbor freight. I installed it and a new sintrifical clutch and it was very fast but going slow in the woods started to burn up the clutch so i pulled the engine back off and im now trying to install a torque converter which isn't an easy task with this mini bike cus the torque converter plate hits the frame and when you put 1 1/2 inch spacers under the engine the gas tank, air filter and exhaust hit the top frame. So i installed the stage 1 kit with an air filter and an outside frame header and bigger main jet. I also pulled the gas tank off so i would have unlimited room on top. But i have a question... the original engines mount holes weren't in the correct spot for the torque converters jack shaft sprocket to line up with the rear sprocket so what is the best way to mark and drill new engine mount holes in the frame thru the 1 1/2 inch square tubing im using for spacers? And another question... can i use the predator gas tank on top of the frame and how can i rig mount it?
