My hybrid Gem
I Figured i would post this here since it is a modified cart in a way..lol... I have had my Gem Car for a couple of years, to use as a local commuter. but after a month i couldn't leave well enough aloan. So i bought a high output electric motor for it, just because the top speed was a mear 25mph.. Well that helped to bring the speed up to around 35mph tops. but it did a number on my battery life, knocking it down in 1/2 to about 15 miles per charge...
Sooo I come up with a plan, Why not stick a gas engine on it to help with the battery life & get me some more speed!.. so i have been looking for a way to do just that, when i stumbled on a Heald trike on C/L..Well that got the gears turning on how i could use the back end of the heald on my Gem... well a grinder a welder and a few months later and this is what i came up with!.. the power plant at first was a predator 212cc, but that was just not doing it so yesterday i went and bought a predator 420cc Engine..
Not only does it give plenty of power, but it also has electric start so no more pull starting!:thumbsup: took it for it's first test run this morning and this thing works great!..the electric engine works the reverse and slow speed, but give it a little more pedal and the 420cc gas engine kicks in pushing it up to 40+ mph, and charges the batteries as well..
The only problem now is the electric motor is governed at 40 tops, so if i try and push it above that speed, the electric motor will brake its self to slow down.. I also need to hook up the gas engine key & starter switch to the cab and figure out if i can use one of the six 12 volt batteries as power for the gas engine starter.. or use a lawn battery...but this is it.. maybe the first Hybrid golf cart!..:shrug:
Nice Cart Murray,I love Arizona, you can street legal just about everything...I have a friend who plated a kawi kx 500 in AZ
Neck
Growing up is optional
GEM's come street legal! We had a few at the City. And, Their front wheel drive, They come with coil over suspension and hydraulic brakes too. They also have a straight rear axle that just begs for a conversion like this. But I wouldn't want to go much more than 40 that's for sure!
Well after a month of driving this thing almost every day, when i started it this morning the Engine spit & sputtered then died. after pulling the choke and trying it again. it started but then sounded like the rod let loose started clattering bad, so shut it off and took the Engine back and guess what, They are out of the 420cc engines. so now I'm waiting on a order of them to come in so i can get back on the road...:doah:
