I'm in the process of cleaning up and painting a HS50 for my JC Penneys/Bird Mini. The question I have is can I plug the nipple for the primer? Will the bike start and run OK without the primer?
I drill out the upper vent hole to same size as a non primer style if I need to cap that line off for the application
Top right is the stock sized vent hole when a primer is not used, bottom is a primer carb like yours with an unaltered vent, top left is one I drilled out and capped the primer inlet.
Glad you're still lurking around! I'm beginning to believe you are right about using a primer. The Trail Bike starts right up but needs to have the throttle opened more than it should until it warms up....a little bit of surge and the bike lurches forward.
