need advice installing hydraulic front brake kit on the coleman ct200 u
what axel should be used to install the Go powersports Hydraulic front brake kit?. the orginal axel seems tooo short to use with the provided spacers in the kit . anyone have any experience installing one of these kits on the coleman 200 u?
If you post some pictures of "this brake kit" and your front wheel, maybe you will get some answers.
I think the kits I have seen, mounted inside the fork, so axle bolt length didn't matter.
what axel should be used to install this brake kit?. the orginal axel seems to short to use with the provided spacers in the kit . anyone have any experience installing one of these kits on the coleman 200 u?
Is it this kit? If so, contact GPS with any questions you may have.
https://www.gopowersports.com/hydraulic-front-brake-kit-coleman-ct200u/
IMO, the CT200U fork isn't sturdy enough for a front brake, not a good brake anyway. That 22mm tubing would probably fold up like a cheap lawn chair under heavy braking.
yes
yes it is the gps front brake kit . I actually did contact gps they told me to order the rear axel bolt which is significantly too long .
Included with the kit:
  • Front wheel assembly
    • 8" front wheel
    • M15 axle
    • Brake disc
    • Bearings and inner crush sleeve included and installed
  • Hydraulic brake kit
    • Master cylinder
    • Brake caliper
    • 34" brake hose
    • Pre-pumped and ready to install
  • Brackets and hardware
    • Caliper bracket with fork mount mount collar
    • Caliper bracket with axle mount
    • 4 x Caliper spacers
    • 2 x Flanged caliper bolts - M8-1.25x40mm
    • 4 x 5/16" lock washers
    • 1 x Washer
    • 2 x Neoprene tape strips - spacer material used in between the collar and fork
This kit is meant only for the Coleman CT200U Minibike with no front suspension. It will not fit any other model. If you have a Coleman CT200U-EX or Coleman BT200X Minibike, then use our Hydraulic Front Brake Kit, Coleman CT200UEX/BT200X for your application.
It looks like the axle is provided with the kit.
    • 8" front wheel
    • M15 axle
    • Brake disc
    • Master cylinder
    • Brake caliper
    • 34" brake hose
    • 1 x Washer
thank you .
    • 8" front wheel
    • M15 axle
    • Brake disc
    • Master cylinder
    • Brake caliper
    • 34" brake hose
    • 1 x Washer
thanks ! im going to get ahold of gopowersports asap
