Purchased a BC1100 and located a rear swing arm which I will install with a jackshaft.
Will be running 8" Bonanza style MX wheels with tires 4.8" wide and 16.4" tall.
Two questions. I am 6'6" tall 275 lbs.
1- What rear shocks should I use ( lbs/sq in?) (8" or 12")
2- what size jackshaft sprockets and rear sprocket should I run? Rear sprocket is simply a ring mounted with allen bolts so come in variety of sizes.
3- any recommended centrifugal clucth you huys tind are quality pieces.
Thanks for the insight.
Dan
Dan
