Might be getting a little too serious about my weed eater bike... I can never seem to leave things alone.
The bike is friction drive and since the first ride I've been trying to come up with a solution to the drive spindle where I can have good traction to the tire in wet or dry.. I've tried just about everything from sockets to PVC with mixed results. The solution that seemed to work the best was a plastic twist grip over my 3/4" socket spindle. It grabbed flawlessly through every puddle, but on the way home from work the same day it shredded completely and left me back at the drawing board. The knurling on the grip worked perfectly in getting the grip I wanted so I went hunting for a chunk of cylindrical metal that was knurled and the only thing I could come up with was the spindles for the staton inc. kits which aren't compatible because I'm running a 25cc Homelite with no clutch to thread the roller into.. so it was back to the drawing board again... After some pretty messy sketches and a couple hours on autocad I came up with this....
I've always thought it'd be cool to have more than one speed, more or less just for the sound of shifting "gears". Basically the roller/spindle will run on 1/2" square stock controlled with a shift fork that will be cable activated by a suicide lever. I'll have a return spring riding on a collar in front of it to push it back to first gear when the lever is disengaged. Looked good on paper so I figured i'd give it a shot, at the very least I'll have a nice desk ornament I can say I designed. With all that said if anyone has any pointers they can throw my way about functionality that would be really helpful. One of the things I was curious about was clearance between the square shaft and the spindle itself. It's currently set to exactly a half inch but I don't know if 1/2" square stock will fit inside with the spindle able to slide smoothly. And also I'm not sure I'm entirely happy with the knurling in the model so I'll have to go back and fix it later as well as dimension everything.
My next obvious concern is I don't own a lathe to even begin making this thing. I looked on evilbay and found some steel 1-3/4"ID-6" round stock for pocket change that might work. But I'm a newbie when it comes to metals so I'm not entirely sure what to look for. I figured I'd ask around on here because I know a handfull of our members own the equipment and are talented with projects like this. I'm trying to avoid being ripped off by a local machine shop but I'm willing to pay for everything from shipping, materials, and hours. I'm really looking forward to making this happen, if anyone is willing to help out or point me in the right direction I'd be really greatful.. I figured I'd start my hunt on one of the best sites on the web. :thumbsup:
Hope to hear from you guys soon.
