Hello,
I just picked up a baja doodle buy on craigslist.
Bike looks to be in great condition except the previous owner's daughter ran into the garage and bent the forks all up. I took front end apart and bent everything back to shape. Got the bike started up on the second pull but noticed an issue.
Seems to be with the clutch. The clutch will not disengage. Even at a low idle, it wants to go. I have to lift rear off ground or it wants to go. When I throttle up with the rear end lifted, it goes faster as expected but makes a loud noise from clutch area.
Is this something that I should just replace the clutch or is there a tutorial somewhere that shows how to remove and fix clutch?
Thanks.
Thanks.
